| Version(s): | 08.11.09.829 | ||
| Environment: | Windows 7 32 bit,Windows 7 64 bit | ||
| Area: | Documentation & Help | ||
| Subarea: | N\A | ||
| Original Author: | Reginald Wallace, Bentley Technical Support Group | ||
How to find listing of all key-ins?
Go to Help>Contents pull-down menu. Once the help menu options click on "MicroStation V8i Help Keyin-in Index".
This will bring up the key-in index dialog with a listing of all MicroStation key-ins. Key-in can also be searched on by using the "Find" field.
http://communities.bentley.com/products/microstation/w/microstation__wiki/creating-tool-icons.aspx
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0109877
