| Version(s): | 22.00.00.15 and higher | ||
| Environment: | ALL | ||
| Area: | STAAD.Pro Licensing Solutions | ||
| Subarea: | N/A | ||
Description
What information is provided by the Bentley License Management Tool?
The Bentley License Management Tool provides details of the current status of all products that you have run locally.
It also provides a method to reserve one or more licenses for when you want to use STAAD.Pro for a long period of time and you are not able to connect to internet.
For more information on using the Bentley Management Tool, see here.
