| Version(s): | 21.00.00.57 and higher | ||
| Environment: | ALL | ||
| Area: | STAAD.Pro Licensing Solutions | ||
| Subarea: | N/A | ||
| Original Author: | Payel Sasmal, Bentley Technical Support Group | ||
Description
How do I turn the advanced analysis option on/off in STAAD.Pro CONNECT edition? I do not see it under 'License Configuration' like previous versions.
Click on OK and exit from STAAD.Pro. Next time when you open STAAD.Pro, you will get the STAAD.Pro CONNECT Edition Licensing dialog box.
Note, these settings are stored in the Registry under
Computer\HKEY_CURRENT_USER\SOFTWARE\Bentley Systems\StaadPro\22.00.00\LicenseConfig
Computer\HKEY_CURRENT_USER\Software\Bentley Systems\StaadPro\21.00.00\LicenseConfig ( for older CE versions)
ProductType 1 configures the program to use a STAAD.Pro license. A value of 2 configures it to use STAAD.Pro Advanced
ShowConfigDialog 1 configures the license dialog to appear when the product starts. A value of zero turns it off.
[[What is STAAD Advanced Analysis?]]
