| Version: | 10.00.00.25 | ||
| Environment: | V8, V8i, CE | ||
| Area: | Batch Processing | ||
| Subarea: | N/A |
How can I change all elements in multiple files to use the ByLevel Color or change all elements in one file to the ByLevel Color using Key-in?
Set up a Batch Process file with the following commands:
CO=bylevel
Choose all
Change color
These same key-ins may also be used in Key-in Browser to change all
elements in the active file to the ByLevel Color
| Original Author: | Lynn Winkler |
