In OpenTunnel Designer 2023 the item type reports are created with duplicate rows. There are two possible solutions to solve this problem:
- the user can place an item type report by using export to CSV file format; after the export the user manipulates the data in the table and place that table in the design file; in this case, if any changes are made in the 3d model that would affect the information from the report, the process needs to be made again to take in to account the latest changes;
- the second solution involves the creation of the report using the option "Current selection" when specifying the elements for which the report will be made.
These 2 workflows are shown in the videos below.
Solution 1
Solution 2
