| Version: | V8i, CONNECT | ||
| Area: | Batch Processing | ||
| Subarea: | N\A |
How to convert DWG references through the Batch Converter
Under the batch converter, go to:
Edit > V8 Save Options > References
Select Convert Reference Files to ON
When set to ON DWG or V7 DGN file with references will then be converted to V8 DGN files
