Cannot Copy/Cut and Paste
 Product:MicroStation
 Version:V8 ,XM ,V8i, CONNECT
 Environment:N\A
 Area:DGN
 Subarea:General
Error or Warning Message
"Elements not written to the clipboard"
From Message Center: "Unable to write to the clipboard file: \[path_to_file]\clipboard.dgn"
Explanation
When copying/cutting and pasting elements using CTRL+C/CTRL+X and then pasting using CTRL + V (or using Edit > Copy, Edit > Cut and Edit >Paste) between files or even within files, MicroStation creates a file called clipboard.dgn in it's temp folder. If user does not have windows privileges to write to this folder, this may cause problems.
How to Avoid
To avoid/resolve, see Wiki on Windows clipboard doesn't work
AskInga - If copying from the clipboard doesn't work
Other language sources
 Original Author:Conor King
