Structural SELECT Entitlements
  Product(s): STAAD.Pro
  Version(s): 2024
  Area: STAAD.Pro Licensing Solutions
The following table lists which items are included with Structural SELECT Entitlements and the Structural WorkSuite license, as well as which STAAD.Pro items and related products require additional license.
STAAD.Pro
STAAD.Pro Advanced
Structural Analysis and Design
Advanced Analysis
Physical Modeler
Structural Wizard
SELECT Entitlement SELECT Entitlement
AutoDrafter  SELECT Entitlement SELECT Entitlement
Composite Beam Design
(Physical Model)
The following support basic functions as noted.
Separate licenses are required for full functionality.
Foundation Design
Isolated, combined, and pile cap foundations only
Connection Design
A subset of basic BCF and BCW connections only
STAAD Advanced Concrete Design
Beam, column, and
wall design only
Nuclear Design Codes
Separate license required
Note: Structural SELECT Entitlements are features in STAAD.Pro that are available only to accounts on Bentley's SELECT or E365 (formerly ELS) programs. These entitlements are also included with Virtuoso Subscriptions. This concept was first introduced in STAAD.Pro CONNECT Edition V22. There is no way to turn these features on if you are not on one of these programs. The Structural SELECT Entitlements are shown in the license dialog as a quick means of verifying access.
