| | Product: | MicroStation | |
| | Version: | All versions | |
| | Environment: | N\A | |
| | Area: | Drawing Aids | |
| | Subarea: | General | |
Problem Description
Cut and paste function doesn't work within a Microstation session.
Reason
It seems that nothing is pasted into the Windows clipboard.
Steps to Resolve
- MicroStation Temp folder is missing or the Windows user does not have permissions to write/modify/read in it.
- Check where MS_TMP points to and if that location does not exist, create the folder.
- This allows MicroStation to create a clipboard.dgn file, which is a that is created when copying anything from MicroStation to the clipboard.
- If the user does have a temp folder check and see if the clipboard.dgn file is present.
Copy / Cut and Paste
Other language sources
| | Original Author: | Sebastien Cote | |
