Document Information
Document Type: FAQ
Product(s): LEAP BRIDGE STEEL
Version(s): All
Original Author: Bentley Technical Support Group -VM
QUESTION: How does the program calculating the Live Load Distribution factor for LL Service I deflection?
ANSWER:
LBS uses the LLDF for shear to calculate deflections.
For LGA - Line Girder Analysis, LBS is calculating the distribution factor for LL Service I deflection as per AASHTO Article 4.6.2.2.3
