Document Information
Document Type: FAQ
Product(s): LEAP BRIDGE STEEL
Version(s): All
Original Author: Bentley Technical Support Group -VM
QUESTION: Is there a way to input bottom flange lateral bracing into the LBS model?
ANSWER:
There is a workaround solution for this issue.
In this way user can assign the bottom flange lateral bracing.
