| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | Analysis Solutions | ||
| Subarea: | Direct Analysis | ||
In a DIRECT ANALYSIS, are the beam deflections for serviceability checks computed using the unreduced E and I values?
By default STAAD uses the reduced E and I for carrying out the beam deflection checks. However in the section 5.37.5 of the Technical Reference Manual ( titled Direct Analysis ), you will find mention of a parameter named REDUCEDEI which can be set to a value of 0, for the full E and I to be considered for computing section displacements.
