| Version: | V8i, Connect | ||
| Area: | Visualization | ||
| Subarea: | Render |
In April 2016 Apple made the decision to deprecate support for QuickTime for Windows. As such security updates will no longer be provided.
With updates no longer being provided this leaves machines open to possible exploitations due to current known and undiscovered vulnerabilities.
With this it is recommended users uninstall QuickTime for Windows or risk potential security threats.
Render Panoramas options for Object Images will be unavailable once QuickTime is uninstalled; these include the following:
Object-Sphere
Object-Circle
Object-Top Hemisphere
Object-Custom
The above features generated an interactive .mov file, when opened within QuickTime or other supported media players.
Note: Regular Cube and Cylinder Panoramas are unaffected.
3D PDF: Directly from MicroStation a 3D PDF can be published for review. Adobe Reader 7.0 or higher required. Benefits include that animations in design files can be played in pdf.
Bentley View: Free application available for review of design files.
LumenRT LiveCubes: Self-contained executables that can be delivered to clients can be generated for review.
Examples of these can be downloaded from the following:
https://www.bentley.com/en/products/product-line/reality-modeling-software/lumenrt/livecubes
https://support.apple.com/kb/DL837?viewlocale=en_US&locale=en_US
https://www.us-cert.gov/ncas/alerts/TA16-105A
http://blog.trendmicro.com/urgent-call-action-uninstall-quicktime-windows-today/
| Original Author: | David Trejo-Rodriguez |
