How to raise a Case in Service Now?
  Product(s): STAAD.Pro
  Version(s): All
  Environment:  N/A
  Area:  Installation and Performance Solutions
  Subarea:  N/A
How to create a Support Case in ServiceNow?
Follow the procedure below:
       1. Type the URL https://www.bentley.com/support/ Click on the Contact Bentley Support
Click on Contact Bentley Support
  1. Select Technical Support as shown below:
  1. Fill in the details below of your query with proper assigned queue and submit.
        4. In addition if you are unable to find the product (software) :
