Access to a path is denied for RCDC FE |How To Fix it
Product(s):STAAD RCDC FE
Version(s):Connect Edition
Environment:
Area:Concrete Design
Subarea:General
Original Author:Aaradhya Rahate, Bentley Technical Support Group
How to Fix Below Error
when you allow app as an administrator, it means you are giving the app special permissions to access restricted parts of your Windows.
Follow the Steps Given below:
1)Right click on RCDC FE icon on desktop
2)Click on properties
3)Compatibility tab
4)Tick on “Run this program as an administrator”
5)Apply & Ok
