| Version(s): | All | ||
| Area: | Seismic Analysis | ||
| Subarea: | IS 1893 (Part 1 and Part 4) | ||
Please check if you have entered the DT parameter representing the depth of foundation. As per clause 6.4.4, the code
requires you to reduce the value of Ah from 0 at the surface to 0.5Ah at 30 m depth and below. The reduction of foundation lying between the surface and 30 metres are to be interpolated linearly between the boundary values.
