| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | STAAD.Pro Support Solutions | ||
| Subarea: | Connection Design workflow | ||
| Original Author: | Abhisek Mandal, Bentley Technical Support Group | ||
In RAM Connection integrated within STAAD.Pro how to assign Base Plate?
To assign baseplate in RAM connection integrated within STAAD.Pro we need to have a column with support at end. Without a support base plate can not be assigned. Now, we need to select geometry cursor as shown below from the right click of mouse.
Then using the geometry cursor, user should select the column and support both. Now you need to go to smart connection templates and assign the required baseplate template to the connection.
