| Defect Number | Description |
| 793722 | Added GCS EPSG:5681 to EPSG:5685 |
| 706075 | Resolved issue with specific DWG file delayed during open |
| 797279 | Rationalized BeTA2010 German GCS |
| 807476 | Resolved issue with logical value displays as Master in Level Manager with empty levels from DGNLIB |
| 637845 | Resolved Keyin issue with export googleearth [Filename] that results in Save File dialog pops up |
| 696939 | Fixed issue with Raster attachment boundary should not be considered for flood calculations |
| 700662 | Implemented CGCS2000 |
| 763172 | Resolved issue with WMS image does not display when you switch from Default to Sheet Model view |
| 808509 | Resolved issue with German BWTA2017.gsb file supporting reprojection from DHDN to ETRS89 |
| 819789 | Rationalize Czech coordinate systems |
| 820544 | Resolved issue with Problem with the display of 3MX Model |
| 854346 | Resolved issue with incorrect interpretation of WKT/PRJ file for Czech coordinate system |
| 820996 | Fixed specific issue with copy PDF as OLE |
| 854630 | Resolved issue with allowing unsimplified mesh |
| 322752 | Fixed issue with specific Accudraw with Measure Area by points method |
| 712034 | Resolved issue with By level assigned text color changes after changing text style through Properties |
| 820173 | Optimized MS_WORKSETMISMATCH_ALERT_EXCLUDE_VARS_WORKSPACELEVEL when defined to generate the list of files from Mapped drives |
| 873406 | Resolved issue where User cannot change Background map Type in the View Attributes dialog box |
| 855521 | Resolved CadWorx Object Enabler display issue |
