| Version(s): | ALL | ||
| Environment: | ALL | ||
| Subarea: | Geometry | ||
| Original Author: | Abhisek Mandal, Bentley Technical Support Group | ||
How to create circular shape plates using Structure wizard? I am trying to change the vector for my case and it is showing below error.
In STAAD model, Structure Wizard has some predefined shapes which can be used to quickly create those shapes in STAAD. Here, below options can be adopted to create a meshed plate of circular shape.
But if you change the Normal Vector direction and click on OK it may throw the error as shown above, In that case, we need to click on "RESET" first and then on OK. This will help to craete the plates.
