| Version(s): | CONNECT Edition (Update 4) | ||
| Area: | FAQ | ||
| Subarea: | N\A |
This is the list of the resolved issues for MicroStation CONNECT Edition Update 4, 10.04.00.46
See HTML Table below
| Defect Number | Description |
| 455647 | Resolved issue importing specific Land XML file. |
| 334903 | Resolved issue where SQL window is dimmed and scrollbar is not working. |
| 391721 | Extrude Along Path takes on the paths Element Class. |
| 407851 | Resolved import of specific STEP file. |
| 469316 | Improved fast preview of camera rotations. |
| 492143 | Resolved sepcific issue with Place SolarPath resulting in crash. |
| 494701 | Resolved XCommand Programming issue in MicroStation CONNECT Edition SDK. |
| 526711 | Resolved specific DWG file crash. |
| 50030 | Resolved the ability to find Arabic numbers. |
| 273792 | Resolved issue with wipeout frames displayed regardless of the WIPEOUTFRAME setting. |
| 442721 | Changes made in remapper do not persist in DWGSetting.rsc. |
| 528272 | Resolved issue with Pull Down Menu Separators. |
| 536456 | Resolved MicoStation hang when opening a specific DWG file. |
| 539661 | Crosshatching is appeared when changing the setting of a template's properties. |
| 363080 | Decimal beyond six digits is truncated by Reference Manager dialog. |
| 403963 | Area visible in reflections with construction off. |
| 491224 | Resolved issue with mdlFence_fromElement. |
| 522581 | Resolved drag and drop text within word processor crashes MicroStation. |
| 527728 | Resolved crash on specific file using the drop linestyle tool. |
| 532588 | Resolved Linestyle Change after using the previous view/Next view group buttons |
| 555376 | Resolved issue with Named Group starting with - + $ % ^ : [ ] characters. |
| 316338 | Resolved issue with Capture Google earth image not working correctly. |
| 317196 | Screen Menu position incorrect when working with multiple application windows. |
| 361935 | Resolved issue with unable to change attached reference file model in specific file. |
| 390017 | Resolved issue with level sorting that shows incorrectly. |
| 550749 | Updated help to explain lights in Explorer. |
| 118114 | Included Trim Solids Feature to the Ribbon Bar. |
| 519686 | Solids (Profile Based) created using 2D Parametric Cell as Profile does not show Cell Variables in Properties Dialog Box. |
| 459287 | Resolved Anti-alaising effect will not appear on element edge low and high value output looks same in render image with "Save Image tool ". |
| 527191 | Resolved VBA .Textstyle properties return wrong values for textelements. |
| 536937 | Resolved issue with "Ignore Default light" not working in effects manager with Glow light effect. |
| 537318 | Resolved issue withMaterial pattern map changes are not updating in view. |
| 539128 | Resolved MicroStation CONNECT Edition hang in specific file. |
| 566380 | Resolved issue with MicroStation CE crash when converting specific files from DGN to DWG. |
| 298699 | Resolved "Dependency callback exceeded" message displays in the Message center when editing dimension with Zero value. |
| 359541 | Resolved dimension failed to be associated with certain parametric cell instances placed by RFA file. |
| 496950 | Resolved issue with ordinate dimensions change value when saving specific file to DWG. |
| 565466 | Resolved issue with custom linestyle not rendering when direction is right to left. |
| 592299 | Resolved incorrect user domain for UTM zones based on ETRS89 in dictionary. |
| 36513 | Resolved ability to have all text in a DGN to convert to Mtext when saving to DWG. |
| 569765 | Resolved issue with specific elements with annotation scale that does not display correctly. |
| 575448 | Resolved issue with custom named expressions that are not recognized for visibilty in split button. |
| 580355 | Resolved issue with specific I-model is crashing when opened. |
| 152610 | Resolved default value for overline offset is "00" rather than "0.00". |
| 344701 | Resolved issue when Microstation hangs while importing specific jt files. |
| 378126 | Place Dimension Tool Settings should show Used Dimension Style in Bold. |
| 423809 | Placing note with Curve multi-leader placing in reverse direction. |
| 478573 | Resolved issue when attaching WMS using EPSG:3059 LKS92/Latvia TM-normal Axis and EPSG:25884 ETR89/TMBaltic93 layer being clipped. |
| 526352 | Resolved issue where Text Justification is always on LeftTop. |
| 536753 | Resolved issue where Element Info table is not visible in the i-model. |
| 569724 | Resolved Tangent Point snap mode will not work with snapping from one existing arc endpoint to create another arc. |
| 580042 | Resolved issue with specific tags rotate after turning the display off and back on. |
| 346763 | Resolved issue in specifici file when when getting the level name in CSV during remap level. |
| 617267 | Non displayed tags are not retained when an element having tags is copied. |
| 620652 | Excel spreadsheet linked in DWG not displaying correctly in specific file. |
| 624373 | Resolved crash when clicking on the empty space in the Cells Library dialog box. |
| 614268 | Resolved issue when keyin: "REFERENCE SET ATTACHMETHOD=geoReprojected reference Bing Map is not automatically reprojected. |
| 561782 | Resolved issue with creation of deployment image installer. |
| 628835 | Resolved issue with i-model hanging when saving to DWG. |
MicroStation CONNECT Edition Update 4 - Announcement
Resolved Defects List - MicroStation CONNECT Edition Update 3
Resolved issues in Microstation CONNECT Update 2
Resolved issues in Microstation CONNECT Update 1
| Original Author: | Maria Munoz |
