| Version(s): | 10.12.00.40 | ||
| Area: | FAQ | ||
| Subarea: | N\A |
Resolved issues in MicroStation CONNECT Edition Update 12, 10.12.00.40
This is the list of the resolved issues for MicroStation CONNECT Edition Update 12, 10.12.00.40
See HTML Table below
| Issue Number | Description |
| 1005893 | Fixed issue with Export Levels to CSV cannot Import the Level Numbers from the CSV in specific file. |
| 967106 | Resolved issue with Command "Dialog Section" > "Section by Projection" > "Element". |
| 967913 | Resolved issue with Georeferenced PDF located incorrectly. |
| 970059 | Fixed issue with saving DGN to DWG incorrectly displaying of filled and patterned shapes. |
| 932069 | Resolved issue with Save as on specific files resulted in Read Only during crash. |
| 776532 | Resolved issue with 3D Parallel / Perpendicular constraint working incorrectly with a particular 2D Line Element. |
| 909850 | Fixed issue with items are selected for this specific file causing a crash. |
| 959690 | Fixed issue with reference display not linking properly with Saved View. |
| 947017 | Fixed issue with Search in items tab leads to crash MS for i.dgn file. |
| 947695 | Resolved issue with specific file with a rotated centroid. |
| 974231 | Fixed issue with Solar Exposure Calculator using North from a reference rather than main file. |
| 916763 | Fixed issue USTN_WORKSETDGNWSTEMPLATE creates two sheet indexes in one file. |
| 659785 | Fixed issue with DGN with attached nested Reference containing shared cell does not display in specific file. |
| 716621 | Fixed issue with specific file exporting 3D DXF or DWG to 2D DGN looses Color Table. |
| 935195 | Resolved issue where Hatches were resulted in file open slowness. |
| 942752 | Fixed issue with Report field does not populate lookup data linked to item type. |
| 694699 | Resolved issue where cells with Tags included appeared graphically smaller in cell selector icon. |
| 957413 | Improved Performance issue manipulating reference files. |
| 964499 | Fixed issue with Text field cannot be placed for named boundary properties. |
| 965774 | Resolved issue where specific GeoTIFF is shifted from correct coordinate location. |
| 863101 | Fixed issue with uneven (Convex or concave) shape masking on 3sm wont get seen in LumenRT. |
| 979381 | Fixed issue using the cells from *.PAT are not being honored with the use of the scale lower than 0.05. |
| 965057 | Resolved issue where Dimension of references resets to 0 when opening models in wrong order. |
| 977731 | Fixed issue where Tags being placed on Default rather than active level. |
| 940153 | Fixed issue with save multiple image with layers from luxology dialog saves wrong image for preview output set in luxology dialog. |
| 947598 | Solved issue with Print preview on a particular file hangs MicroStation CE. |
| 934397 | Resolved issue with Modify Solid (Mode : Modify Face), does not generate preview while developing through cut on Solids. |
| 385197 | Fixed issue with Background image won't get seen in output image from Tone map bing file. |
| 468482 | Fixed issue with Solar wont get exported to LXO if SUN intensity = No SUN. |
| 670860 | Resolved issue with Save image tool that did not remember last used location for save image ,user required to navigate to desired location each time when use "Save Image". |
| 700255 | Fixed imported LXP materials that would not get seen on element in rendered output. |
| 945221 | Resolved specific issue with Measure "Along Element" in specific file. |
| 8776 | Resolved issue with Import Coordinates not handling file paths longer than 125 characters. |
| 158946 | Fixed specific issue with Export to FBX in specific file. |
| 800955 | Resolved issue with specific STEP export being incomplete. |
| 916971 | Fixed issue where Levels from dgnlib are temporarily lost when compressing DGN file. |
| 327898 | Fixed issue with HTML Author is not working with Microsoft Edge in Windows 10. |
| 958085 | Fixed issue with DIN dimension is not displayed correctly in DWG. |
| 959536 | Fixed issue with _USTN_USERCFG is locked by the application. |
| 960793 | Resolved issue where specific DWG file's MText is not displaying correctly, displays multiline instead of single line. |
