| Version(s): | 10.10.00.23 | ||
| Area: | FAQ | ||
| Subarea: | N\A |
Resolved issues in MicroStation CONNECT Edition Update 10, 10.10.00.23
This is the list of the resolved issues for MicroStation CONNECT Edition Update 10, 10.10.00.23
See HTML Table below
| Defect Number | Description |
| 323593 | Resolved issue where some Toolboxes are moving |
| 362916 | Resolved issue where XYZ Text Import Coordinates using Text as markers not placed on Active Level. |
| 630573 | Fixed issue with specific WMS image displays in MicroStation V8i, but does not display in MicroStation Connect Edition. |
| 814071 | Resolved issue with crash in MicroStation Connect Edition when using key in: LINKS ADD ELEMENT BYSELECTEDNODES. |
| 883913 | Resolved issue when editing property of text sytle causes color change |
| 556002 | Improved performance when MicroStation startup with large list of Worksets |
| 885977 | Fixed issue with MicroStation hanging when selecting specific cells in cell library with Properties dialog open. |
| 887628 | During reference attachment the file is getting self-referenced when Master file and Ref file have same name located in different directory |
| 886684 | Improved Element Template search perfomance |
| 679271 | Fixed auto propagate in cell library |
| 811082 | Resolved issue with Modify solid in specific file to hang |
| 212789 | Resolved issue with specific file that is in ACIS SAT format elements to not import correctly |
| 883041 | Fixed issue when clipping reality mesh which reality mesh display switched off, clipped mesh is not visible |
| 883379 | Resolved issue with specific DWG not opening correctly in MicroStation CONNECT Edition |
| 870789 | Fixed issue with In Camera View, 3D Dimension constraints placed between edges/axis of Solids appear abnormally larger in size |
| 863024 | Resolved issue with specific DGN Elements not publishing their Geometric properties to an imodel |
| 868422 | Resolved issue with specific solid where Modify Solid doesn't work properly |
| 868556 | Resolved issue with the "Color" in the print dialog box does not change if the previous .pltcfg or if the user had manually set it to Monochrome with the load of a .pltcfg with "Default Color Mode" set to "True Color" |
| 805436 | Fixed issue with 16 bit Tiff image is not correctly showing when attached as a raster in a dgn |
| 854410 | Resolved issue with SingaporeGrid.Kertau (or EPSG:24500) |
| 866989 | Fixed entries in tree hierarchy for Czech coordinate systems |
| Original Author: | Maria Garcia |
