| Version(s): | 08.11.07.492 | ||
| Area: | FAQ | ||
| Subarea: | N\A | ||
Fixed 08.11.07.443 - 08.11.07.492
What is fixed between 08.11.07.443 and 08.11.07.492 ?
Product: MicroStation V8i
Version: 08.11.07.492
Area: Fundamentals, GENERALINFORMATION
Here is the list:
311031 - [Geographic Coordinate System] Sweden coordinate system SWEREF
99 18 00 has slightly different definition (inverted axis) than
EPSG:3011 while internally mapped one to the other.
310640 - Request for Geographic Coordinate System for Singapore (SVY 21)
261423 - The "Move to Contact" tool does not move all elements as
expected
287864 - Incorrect angles are being reported with the Label Line tool.
307960 - When publishing an AutoPLANT model - some of the elements come
across as AutoPLANT dgn types - so they require the AP element handler.
312197 - Using hpglrtl.pltcfg with Border On = true, any Border text \
comment = true, and Fence outline on = true, the fence outline prints at
the correct origin (0,0). However, the drawing is printed with a 3/8
inch offset.
312060 - Move to Contact tool is bypassing elements for text elements.
310531 - When we export a DGN file to a Collada file, the result is not
correct.
311821 - Crash after using Insert Dimension tool with existing dimension
on Cone element
313423 - After installation of PWG Admin when creating BG Map from
remote XP machine, getting MMC crash error.
313357 - The displayed markups are not automatically detached when the
file is closed in MicroStation.
313377 - The markup Display On check indicators are not persisted
between versions.
314364 - Merge into Master impossible
313819 - DWG export: external attachments - merged to cells - are
missing
310331 - IPLOT can't plot elements with tags. The plot / preview process
is resulting in a exception log
314223 - Memory not releasing in Batch Process for Materials.
315267 - Wrong scaled tags nested in shared cells
D-81218 - Relationships are lost after doing DesignHistoryRevert
291715 - Ms Crash assigning a saved view to a view with "Window" option
selected.
308911 - Significant degradation in performance of Print Organizer when
working with PW managed workspaces.
316098 - ProjectWise MCM checkin cause MicroStation crash due to NULL
model ref pointer when there is no active design file.
314449 - WMS doesn't manage custom GCS as expected
D-82210 - I-models cannot be processed if they are located over a
network path.
316171 - A fatal error has occurred when "Discarded Invalid Entities" is
enabled.
