| Version(s): | CONNECT Update 6 | ||
| Area: | FAQ | ||
| Subarea: | N\A |
This is the list of the resolved issues for MicroStation CONNECT Edition Update 6, 10.06.00.38
See the details in the Table below.
| Defect Number | Description |
| 329761 | Resolved issue with MicroStation pdf file not measuring correctly in Adobe products. |
| 691332 | SDK Help WPF topic makes reference to 32-bit MicroStation CONNECT |
| 691335 | SDK Typos in Help Topic - Working With Schemas > Best Practices |
| 703030 | Resolved crash when renaming sheet model from Model dialog which has saved view reference without drawing boundaries. |
| 704195 | Resolved issue when Global Origin is Shifted from Design plane center then Exported ACS has cordinates with respect to Design plane center insted of Global origin. |
| 635470 | Fixed issue with VBA method .GetTotalTextSize returning incorrect values. Width from single character and both values in UOR |
| 650706 | Resolved crash when Importing specific CGM files. |
| 668343 | Fixed issue when fence mode set to CLIP after doing Key in: ff= to save the elements in a new file option clip Works exactly as the option inside. |
| 378038 | Resolved issue where Fence used in Reference tools are not recognized by the tools. |
| 699686 | Resolved issue with 'Synchronize/Follow/Capture Google Earth View' tools are not working with Google Earth PRO version. |
| 699718 | Resolved issue when Feature solid will not show material texture in view if changes in View brightness or Zoom in or out view are done. |
| 699721 | Resolved issue when attachment selection border remain on element, even when deleted from attachment entry from material under material editor. |
| 528101 | Resolved issue with VBA help in MicroStation CONNECT Edition still refers to V8i. |
| 677593 | Resolved issue when specific DWG file takes more time to open compared to MicroStation V8i. |
| 698824 | Fixed issue with specific DWG file opening slower in MicroStation CONNECT Edition compared to MicroStation V8i. |
| 687391 | Resolved issue with Accudraw polar mode not working correctly in specific file. |
| 455496 | Resolved issue where attachment selection border remain on element even if we deleted attachment entry from material under material editor. |
| 740404 | Added support for DWG Block description definition property. |
| Original Author: | Maria Munoz |
