| Version(s): | 10.11.00.36 | ||
| Area: | FAQ | ||
| Subarea: | N\A |
Resolved issues in MicroStation CONNECT Edition Update 11, 10.11.00.36
This is the list of the resolved issues for MicroStation CONNECT Edition Update 11, 10.11.00.36
See HTML Table below
| Issue | Description |
| 930444 | Resolved issue with CurveVector.ClosestPointBounded |
| 886188 | Resolved issue when applying Element Template with custom Item Type. |
| 870170 | Fixed issue with complex mesh case with Mesh Boolean |
| 930246 | Resolved issue with Material Attachment is not seen in the Material Editor until a reopen of the file after Undo opration |
| 926697 | Fixed issue with Offset XYZ components in properties pane need to be editable. |
| 925741 | Fixed issue with Delete vertex tool deletes all collinear vertices in a line segment. |
| 916939 | Resolved specific issue with MicroStation when compressing DWG files to remove unused levels |
| 918345 | Improved OBJ export. |
| 905206 | Resolved specific issue where new elements are displayed after reference merge. |
| 899491 | Fixed issue with Material attachment is not seen in the Material Editor until a reopen of the file. |
| 899559 | Fixed issue with Material still seen on Parametric solids even after removing the Attachment. |
| 872603 | Fixed issue with specific solid where Modify Solid (Mode : Modify Face), does not generate through cut. |
| 861868 | Resolved issue with Reprojection causes Reload detection. |
| 886775 | Fixed issue when saving specific file to DWG where the pattern scale changes from 1:50 to 1:1 |
| 486340 | Resolved issue with the Imprint Tool (Mode : Offset Solid Edges) not able to select multiple edges of solid to offset. |
| 681638 | Fixed issue with Find Replace with Regular Expression option BeginningOfLine hangs application. |
| 719106 | Resolved issue in specific file where two Solar exposure analysis have different results. |
| 734635 | Level flags should be considered for point cloud data. |
| 923150 | Fixed issue with specific solid extruded from AEE behaves incorrectly when parent is rotated. |
| 560354 | Fixed issue where use mdlLevel_create causes temporary wrong level behavior in level display |
| 872026 | Fixed issue with Display Rule Symbology does not apply correctly on Cells and Shared Cells |
| 882316 | Resolved issue with specific file where Level display off if there is more than 64 levels in a file fails when the levels are created in same session. |
| 883934 | Fixed issue with Export Coordinates tool is exporting text element location as zero. |
| 898567 | Resolved issue with specific Level Library causing a crash. |
| 905505 | [Crash][Regression][From SS4] MicroStation crashes while opening the view group dialog. |
| 670866 | Resolved issue where Export Coordinates tool not exporting coordinates of text. |
| 905732 | Resolved issue when Text Favorite causing a crash when selecting an array ratio. |
| 885393 | Resolved issue with crash when save as on specific file. |
| 799046 | Fixed issue with Export VISSIM file into LumenRT vehicles are offset from the its original route. |
| 883899 | Fixed issue with Compress changing the active ByLevel Linestyle in the Ribbon Attributes Group |
| 378203 | Remove MS_WORKSPACEOPTS variable from CONNECT Edition. We have new MS_CONFIGURATIONOPTS |
| 386158 | Resolved issue where MicroStation would crash when loading specific .rsc file in FontUtilities. |
| 697470 | Resolved issue where Calculating Area of specific file returns incorrect result. |
| 939809 | Fixed issue with specific file with Calculating Area giving incorrect result. |
| 681414 | Resolved issue with single packaged iModel not displaying in Windows preview pane |
| 930463 | Capability to Attach an item type from a dgnlib library directly |
| 799430 | Resolved specific crash while opening attached IFC file. |
| 541573 | VBA method GetFloodBoundary expects Point in UOR instead of working units |
| 816649 | Fixed specific issue where cells in a group are deleted. |
| 853638 | Fixed issue with VBA runtime error after modifying nested reference attached. |
| 898105 | Memory leak occurs with VBA method RaySolidIntersection |
| 467398 | Reduced the time for MicroStation to switch to the Backstage. |
| 759657 | Resolved issue with the Measure Area by flood and by element return different results on grouped hole. |
| 898546 | Resolved issue with creating a new file using seed.dwg file, insert object after closing and reopening file three times user gets ”this OLE object was inserted as a static picture. It cannot be activated” |
