| Version(s): | 08.11.09.829 | ||
| Area: | FAQ | ||
| Subarea: | N\A | ||
| Original Author: | Maria Munoz | ||
A list of the resolved issues for MicroStation V8i (SELECTseries 4) is available in the Readme file supplied within the installation folder:
C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\readme_MicroStation.chm
It is also available for downloading within Bentley Communities:
https://communities.bentley.com/products/microstation/m/microstation_gallery/271717
List of Resolved Issues for MicroStation V8i (SELECTseries 4)
ID |
Work Item Type |
Title |
331820 |
Defect |
Failed to install due to error related to OS |
292529 |
Defect |
'Export Resolution' is displayed UOR times in Properties dialog |
328451 |
Defect |
Unable to Publish DGN linked callouts files by a certain View approach. |
317338 |
Defect |
Custom linestyles bleed over into cut graphics in the print output |
189970 |
Defect |
incorrect definition of JGD2000 datum (and EPSG:6612 duplicate) in dictionary of coordinate systems |
217609 |
Defect |
Resolved issue where elements outside of saved vies is not published. |
214512 |
Defect |
Orientation values are missing from an i-model generated using a Saved View. |
37423 |
Defect |
Resolved issue where Open Target results in success, though the Message Center returns 'Follow Link Failed' in specific file. |
98898 |
Defect |
Division by Zero when using custom GCS based on TM using BF computations |
69924 |
Defect |
Incorrect definition of GCS entries EPSG:3000 to EPSG:3002 |
70816 |
Defect |
Resolved incorrect generation for PDF printing using DGN with custom GCS using 'Millimeter' units. |
290811 |
Defect |
An error occurs when saving dgn as dwg on clean OS. |
273486 |
Defect |
Lots of recurring messages regarding password minimum criterion appear in message center. |
254261 |
Defect |
Application crashes during .imodel creation if the existing issues.log file is set Read-Only. |
157148 |
Defect |
Text Background Border Offset changes to 0 when using the Change Text Attributes tool to change text style |
117579 |
Defect |
Resolved missing elements when zooming in specific file. |
110258 |
Defect |
Cannot turn off Text and Tag display from section |
102402 |
Defect |
Resolved conversion of specific xyz file to pod file crash. |
93824 |
Defect |
Correction of ED50COMOFF datum for connector |
89418 |
Enhancement |
Using Selection tool to select an individual element within a Graphic Group only manipulates that one element. |
79164 |
Defect |
Referenced file Default Level Color Override not saving |
73080 |
Defect |
Resolved Geographic Coordinate System transformation Nad27to CSRS using given GDC file |
73302 |
Defect |
Resolved Crash when toggling off a specific class after compressing Dgn. |
66821 |
Defect |
Resolved issue of being able to open specific DXF |
66867 |
Defect |
Raster Image Not Displayed in MicroStation |
65205 |
Defect |
Reproject the Raster with the same CS model where it is attached. |
65287 |
Defect |
MicroStation crashes on file open. Related to text in reprojected reference. |
65486 |
Defect |
Resolved KML Export shifting in specific file. |
52813 |
Defect |
Resolved Distributed Rendering with Animation on large datasets |
61342 |
Defect |
Resolved MicroStation hangs with reference file attached with different drawing scale with Annotation Scale. |
63197 |
Defect |
Resolved 3D PDF animation showing gap between actors. |
63214 |
Defect |
Custom linestyle display incorrectly in specific DWG file. |
45198 |
Defect |
Resolved invalid strings are found in Rules Template dialog. |
37559 |
Defect |
Error message when closing out of a specific DWG file. |
36206 |
Defect |
Added option in the i-model publish settings that would force the publish to honor the "ignore attachment when live nesting". |
36207 |
Defect |
Added ability to not publish references with display OFF. |
25261 |
Defect |
Non-plot layers that are not displayed become visible in the output DWG when exported. |
25265 |
Defect |
Resolved activating a view turns ON the active level regardless of whether the Operations Preference 'Display Active Level in All Views' is OFF only if the Level Display dialog is open. |
24238 |
Defect |
Ability to export Sheet only DGN exports to DWG Model space. |
24383 |
Defect |
Performance improvements on Draw Section Graphics. |
23728 |
Defect |
Resolved text shifting in Title Text in Detailing Symbols. |
23751 |
Defect |
Resolved issue with wait time for Add vertex of Modify Facets |
23238 |
Defect |
Resolved issue with Mesh from Points. |
22886 |
Defect |
Resolved EC attribute inherit problem after mesh being processed. |
19423 |
Defect |
Resolved issue with no graphics being displayed for specific IFC file with swept disk solid. |
16399 |
Defect |
Resolved Hatch and Patterns displaying on the same level as geometry in dynamic views. |
Forum thread:
http://communities.bentley.com/products/microstation/f/273/t/117364
Bentley's Product Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section.
For questions or comments unrelated to this article please post a new discussion in this community's forum with a link to this Wiki.
