| Version(s): | All | ||
| Area: | STAAD.Pro Support Solutions | ||
| Subarea: | Physical Modeling workflow | ||
| Original Author: | Modestas Turulis, Bentley Technical Support Group | ||
Is it possible to hide the selected elements in the SPPM? If yes, how?
Yes, it is possible to hide the select elements in the STAAD.Pro Physical Modeler (SPPM). These steps may be followed:
1) Select the elements which you want to hide.
2) Go to Data menu and click Invert selection. Then click Select Objects icon:
Now all the items selected initially will be hidden. To restore the default view, click the Selected Objects icon one more time.
