| Version(s): | CONNECT Update 7, 10.07.00.39 | ||
| Area: | FAQ | ||
| Subarea: | N\A |
This is the list of the resolved issues for MicroStation CONNECT Edition Update 7, 10.07.00.39.
See the detail in the table below:
| Defect Number | Description |
| 592430 | Resolved incorrect interpretation of ESRI SHP geocoding. |
| 619707 | Resolved bubble in elevation callout placed at certain angles is not displayed when "Fill" is ON. |
| 632240 | Resolved issue with specific DGN file crashes upon opening. |
| 645760 | Resolved spcific issue where crash occurs when selecting variable for MS_MDL. |
| 663451 | Resolved issue with changing view attributes from wireframe to smooth, after user drape Bing map over mesh. |
| 666371 | Fixed issue with incorrect display of annotation scale in French version. |
| 668046 | Resolved issue with MicroStation crash while using msbatch for Converting 2D-3D files./td> |
| 672238 | Fixed issue with gradient fill not properly displayed in MicroStation CONNECT Edition |
| 683755 | Resolved specific issue when importing a certain STEP file resulting in no elements imported. |
| 691609 | Resolved crash with specific STEP file during import. |
| 693731 | Resolved issue with maximize a camera view, changes the perspective of the view and the view itself. |
| 694090 | Resolved issue with Face Attachment will not working correctly for external materials. |
| 694453 | Resolved issue where blip boundaries are ignored during printing in non-rasterized mode to printer driver incapable of non-rectangular clipping. |
| 697554 | Fixed material assignments from .pal library materials when there is an internal palette file with the same name don't show in the material editor. |
| 701057 | Resolved issue when saving as dwg, text that are superscripted without a main body resulted in DTEXT’s using the main body’s text size. |
| 706270 | Resolved issue with Sweep Edge Feature does not relocate its constrained profile as per the changes made to Variable values. |
| 712262 | Resolved issue with Web Map Service display issue with MicroStation CONNECT Edition and Windows 10. |
| 717244 | Resolved issue where specific DGN does not save as DWG. |
| 720122 | Fixed issue with special text character display issue. |
| 722130 | Resolved issue with Thematic display accuracy depends on the total size of the spectrum. |
| 722202 | Fixed issue with specific file an existing element has changed its level after Save operation. |
| 723632 | Resolved issue with Edit Fields using the field type from elements (in a parametric Cell) does not recognize the property values from Variables TAB that are defined as a variable. |
| 725172 | Resolved issue with exported dgn (working units in meters) to SKP is automatically converted in inches. |
| 726467 | Resolved isue with lowercase letters are being changed to capital letters when insert data to Oracle database. |
| 730510 | Field issue in specific file where incomplete geometry is getting Imported from IGES file with option "Stitch imported sheet bodies into a solid". |
| 744331 | Resolved issue where the specific mesh element's indices are incorrectly created in DWG. |
| 747206 | Resolved issue when Editing a specific Field using an element as a Signature Cell MicroStation throwing Unhandled Exception. |
| 747377 | Resolved issue where editing specific material in Material Table Edit causes MicroStation to crash. |
| 747403 | Fixed issue with attaching a specific .3mx resulted in an error message on save. |
| 748228 | Resolved issue where DWG Filled Area ByLevel Color displays incorrectly. |
| 754995 | Resolved issue where specific dgn file has failed to open. |
| 726620 | CONNECT update with Oracle server DB 32 bits (also 64 bits which is certified) version 11g and Oracle cliente a 64bits when INSERTING data in lowercase letter translates data to CAPITAL LETTERS. |
