STAAD Advanced Concrete Design (RCDC)
ROBUST CONCRETE DESIGN WITH STAAD ADVANCED CONCRETE DESIGN (RCDC)
DETAIL - DRAW - DOCUMENT - DELIVER WITH STAAD ADVANCED CONCRETE DESIGN (RCDC)
STAAD Advanced Concrete Design (RCDC) is an industry leading concrete design & detailing software. It is a powerful software that delivers a completely seamlessly integrated process linking analysis to design & detailing, drawings, estimation and reporting.
STAAD Advanced Concrete Design (RCDC) is used across a wide spectrum of industry including High-rises, residential, commercial, industrial and infrastructure projects.
Visit the STAAD.Pro product Page for additional information on this product.:
LEARN
View STAAD Advanced Concrete Design (RCDC) Learning Paths on the Bentley Learn Server
Walk through the Concrete Design with STAAD Advanced Concrete Design (RCDC) Software as a whole and understand where it perfectly fits in for you
Walk through the Detailed video for Designing of Columns and Walls - Part 1  and Part 2  in STAAD Advanced Concrete Design (RCDC)
Walk through the Detailed video for Designing of Beams - Part 1  and Part 2 in software
Walk through the entire Footing Design Workflow and also Water Tank Designing and Detailing Workflow in software
Download
You can download the latest version of STAAD Advanced Concrete Design (RCDC) from Bentley's Software Downloads.
STAAD Advanced Concrete Design (RCDC) is available under a Structural Work Suite. Learn more.
Support
STAAD.Pro Support Solutions
