Dynamic wind loads are the fluctuating loads that result from wind turbulence and the interaction between the wind and the structure. Therefore, they are partial results and should be added to the principal component at the main wind direction, the static result to form together the final wind total result.
communities.bentley.com/.../rm-bridge-wind-analysis
