Product: | MicroStation | ||
Version: | CONNECT | ||
Environment: | N\A | ||
Area: | Parametrics | ||
Subarea: | General |
Having created a Parametric Solid by Extruding a Profile, I want to edit the Parametric Solid by replacing the Profile with another.
To replace the profile
5. Select the newly drawn required profile and except with a Data point in the View
Original Author: | Carl Myhill |
