| Product(s): | STAAD Foundation Advanced | ||
| Version(s): | Connect Edition | ||
| Area: | STAAD.Foundation Advanced Installation/Licensing Solutions | ||
| Subarea: | Installation | ||
| Original Author: | Payel Sasmal, Bentley Technical Support Group | ||
How to perform a clean installation of STAAD Foundation Advanced CONNECT Edition?
These steps should be followed to completely uninstall STAAD Foundation Advanced CONNECT Edition from the machine and then install a new version.
Note: There are few free software available (for example, Revo Uninstaller) which can uninstall the software, delete leftover files and delete the related registry files (perform step 3 and 4). If any of this software is used to uninstall STAAD Foundation Advanced CONNECT Edition, step 5 should be performed to ensure that there are no leftover files present in these locations. If you are not comfortable in updating the registry, you must seek help from your IT department.
