| Version: | V8i | ||
| Area: | Configuration | ||
| Subarea: | Workspaces |
Delivered tools are missing.
When I start MicroStation I do not see the delivered tools and tasks.
GUI.dgnlib needs to be included in _USTN_SYSTEM_GUIDGNLIBLIST
Starting with MicroStation V8i SS3, the delivered interface tools/tasks context menus are now stored in a file named "GUI.dgnlib".
If _USTN_SYSTEM_GUIDGNLIBLIST was changed in a custom configuration and does not load the DGNLIBs that are in "...\Workspace\System\GUI\", it will cause the delivered tools to be missing (not show) when
MicroStation is started.
To resolve:
Modify configuration so that _USTN_SYSTEM_GUIDGNLIBLIST includes Bentley\MicroStation V8i (SELECTseries)\Workspace\System\GUI\*.dgnlib
OR
Copy GUI.dgnlib to the location where _USTN_SYSTEM_GUIDGNLIBLIST is currently pointed.
Warning, make a backup if you intend to modify this file as it is the ONLY source for the delivered tools. Once a tool is deleted from this
file, it is gone.
