| Version: | CONNECT | ||
| Area: | GUI | ||
| Subarea: | Ribbon |
Is there a keyin or hot-key available to change the type of ribbon workflow selected in the pulldown menu?
The default hot-key available in the Keyboard Shortcuts is "\" and the key-in relating to this is:
RIBBON MENU WORKFLOW
or to select a specific workflow
RIBBON SETWORKFLOW DRAWING
| Original Author: | Andrew Bell |
