Here are the steps to create a hammerhead pier with circular columns:
- Open Substructure module and navigate to Geometry tab, open Pier Config dialog:
- Set the Pier Type to Multi Column,
- Cap Shape as Tapered and
- Column Shape Round.
- Click on Cap and set the Tapered Cap Geometry (see example below):
- Click on Column and set the desired column dimensions (see example below):
- Click on Footing and set the footing geometry:
