| Version(s): | 08.11.09.459 | ||
| Area: | Dimensions | ||
| Subarea: | General |
How to place multiple points along a path where the path intersects with other surfaces. Having obtained the points their coordinates can be exported to a text file using the XYZ Export Coordinates tool.
Note a prerequisite is that the graphics needs to be in a 3D file.
From the 'Surface Modelling' task select the 'Compute Intersection' tool and except the selected elements ( data point in view ) and then select and except ( data point in view ) the path element
| Original Author: | Carl Myhill |
