| Environment: | Windows 10 64 bit | ||
| Area: | Base Geometry | ||
| Subarea: | N\A | ||
| Original Author: | Judy Wong, Bentley Technical Support Group |
In previous version of V8i, there was a “offset element tool” that used to be in the “Create Curves" dialog ?
I can’t find it in the new version. Copy parallel doesn't keep the elevations of the original element in a 3D environment.
You can type in Key-in Browser, command line is : CONSTRUCT CURVE OFFSET
See
Other Language Sources
