| Version: | V8i | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles |
How do you change the text justification of a Note
In the Dimension Style setting box (Element>Dimension Style), under the Note category, you can set the justification as you would want it, and then use the "Change Dimension” tool to make the change. See image.
| Original Author: | Judy Wong |
