| Version(s): | 08.11.09.459 | ||
| Environment: | Windows 7 32 bit,Windows 7 64 bit | ||
| Area: | Drawing Aids | ||
| Subarea: | Snaps | ||
| Original Author: | Reginald Wallace, Bentley Technical Support Group | ||
Using "construct perpendicular to" tool.
1. Set snap mode to nearest
2..Keyin 'construct perpendicular to'
3. Select first element i.e. select a line
4. Hit and hold the Ctrl+Shift keys
5. Select second element i.e. parallel line
The Ctrl+Shift allows the tool to use accusnap for element placement
Other Language Sources
