Logging a new Feature/Enhancement request for STAAD.Pro
Product(s):STAAD.Pro
Version(s):CONNECT Edition
Environment:ALL
Area:STAAD.Pro Download/Installation/Security/Performance
Subarea:Performance
Original Author:Modestas Turulis, Bentley Technical Support Group
How can I suggest a new enhancement or a feature for STAAD.Pro?
Since March 2023, suggestions for new enhancements/features should be logged in the Bentley Ideas Portal. You will be able to see all our products that have Bentley Ideas portals. Please go there to submit new ideas, see the status of your previous ideas, and vote and comment on others’ ideas. As an active user, your ideas help us better understand what you really need!
To submit this as a new Idea:
• Make sure you are logged in to Bentley Communities
• STAAD.Pro Ideas Portal should be used specifically for STAAD.Pro. Access the Bentley Ideas Portal for any other Bentley application (RAM, AutoPipe, SACS, MOSES, etc.).
• Click “Add a new idea” and enter the information requested. The more details the better!
• Click “Share Idea”. You are now subscribed to this idea, and unless you opt out, you will get emails whenever this idea is updated.
• Your idea will now be reviewed directly by Product Development team and given a status.
• You can come back to the portal any time to see the status of your idea(s) in each product’s portal.
Benefit of Aha! Portal:
You can access each product’s Bentley Ideas Portal through Bentley Communities
You can browse by most recent, trending, and popular ideas
You can comment/vote on ideas
You can filter ideas by category, or status and search by name
Portal ideas can be translated to English, Spanish, German, French and Dutch making it easy to share ideas in the language of your choice
