If you created an alignment or a profile without setting an alignment name or a profile name. This usually happens when one forgets to set a Feature Definition.
To set the alignment/profile name please use these steps:
- From the OpenBridge Modeler > Civil workflow, open Set Feature Definitions dialog
- Set the Feature Type to Alignment, Set the Feature Definition to the desired feature and Enter the Alignment Name. In the example below Feature Definition is set to Geom_Baseline and Name is GeomBL.
- Locate the alignment and reset to complete. This will set the Feature Definition as well as the Feature Name.
NOTE: Make sure to select the 2D alignment.
