How to create separator lines in MicroStation customization menus?
How to create separator lines in MicroStation customization menus, for example in the right click contextual menu?
  1. Add an additional "New Menu Item"
  2. Use a single hyphen (-) as the "Label" and left everything else blank
Forum thread: CONNECT - Pull Down menus
