OpenBridge Modeler
Now Available, the first Commercial Release of OpenBridge Modeler CONNECT Edition. v10.03.00.03.
Bridge Modeling on the MicroStation CONNECT platform and OpenRoads with OpenBridge Modeler CONNECT Edition, OBM CE.
Key Features:
3D parametric bridge modeling focusing on:
    Segmental bridges (span-by-span and balanced cantilever)
    Box girder bridges
    Slab bridges
    Prestressed concrete girder bridges
    Steel girder bridges
    Extensive substructure modeling
        Piers (multi-column, pile bents, wall piers, & custom piers)
        Abutments (stem wall and pile cap)
        Bearings and bearing seats
Reference or import of civil data, from legacy Civil products or OpenRoads Designer
    Horizontal alignment, vertical profile, terrain
    From GEOPAK, InRoads, MXRoad native files
    Civil consensus model
Analytical connection
Geometry reports
    Input echo
    Deck elevations
    Bearing seat elevations
Estimated quantities and cost reports
Generate i-models with engineering attributes
Download the installer from Fullfilment Center ( Software Downloads).
Installation Requirements
FAQ
Readme
Trademark and Copyright
communities.bentley.com/.../now-available-openbridge-modeler-2023-release-v23-0-0-200---november-2023
