The Bridge products will perform optimally if the recommended System requirements as outlined below are adhered to.
Processor
Intel Pentium-based or AMD Athlon-based processor 2.0GHz or greater
Operating System
Memory
16 GB minimum 32 GB recommended. More memory almost always improves performance, particularly when working with larger models.
Video
1GB of video RAM or higher recommended
Disk Space
25 GB minimum free disk space
