| | Product(s): | MicroStation | |
| | Version(s): | 08.11.09.919 | |
| | Environment: | Windows Server 2016 | |
| | Area: | Database | |
| | Subarea: | ODBC | |
User gets the following error
Connection Failed:
SQLState: '01000'
SQL Error: 1
[Microsoft][ODBC SQL Server Driver][DBNETLIB]ConnectionOpen (SECCreateCredentials()).
Connection failed:
SQLState: '08001'
SQL Error: 18
[Microsoft][ODBC SQL Server Driver][DBNETLIB]SSL Security error
Machine Details
Operating System – Windows Server 2016
SQL Server version - 2017
MicroStation version – 08.11.09.919
ODBC version and bit (32/64) – N/A
Several known vulnerabilities have been reported against SSL and earlier versions of Transport Layer Security (TLS 1.0, TLS 1.1). We recommend that you upgrade to TLS 1.2 for secure communication.
Download the latest ODBC Driver for SQL Server that support TLS 1.2
You may need to enable TLS 1.2 for SQL Server communication if disabled.
What is the correct registry setting to enable TLS 1.2 for SQL Server communication? The correct registry settings are as follows:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.2]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.2\Client] "DisabledByDefault"=dword:00000000 "Enabled"=dword:00000001
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.2\Server] "DisabledByDefault"=dword:00000000 "Enabled"=dword:00000001
Connecting to MS Access Database from MicroStation Connect
Other language sources
| | Original Author: | Leonard Jones | |
