| Version: | XM, V8i, V8i SELECTseries, CONNECT Edition | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles |
When placing Dimensions in a view, the dimension is placed as scaled (either too large or too small). Annotation scale is not turned on or set when placing dimension. See image 1 below showing dimesion (both dimension text and terminators appear scaled, dimension text in this case should be 20 mm)
Image 1
Image 2
Image 3
| Original Author: | Conor King |
