| Version: | V8, XM, V8i, CONNECT | ||
| Area: | Levels | ||
| Subarea: | Level Display |
When opening a file that has a reference attached, elements (e.g. text and lines) on some levels do not show. For example, when a Sheet Model has a Design Model attached as a reference and the elements are displayed as desired when the Design Model is opened, but the same elements are not shown in the Sheet Model when they are expected to be. Checking in Level Manager and Level Display, all reference levels appear to be turned on. If the reference file is opened directly, all the elements are displayed. How can these elements be displayed in the master file?
The issue could be caused by a setting/toggle in the Level Display dialog;
Global Display controls the display of levels for all views. View Display only controls display for the selected/active view.
| Original Author: | Conor King |
