| | Product: | MicroStation | |
| | Version: | V8, XM, V8i, CONNECT | |
| | Environment: | N\A | |
| | Area: | Levels | |
| | Subarea: | Level Display | |
How to set a Function Key to turn off the level display of all levels in the view
It would be useful to have a quick keyboard option to turn off and on the display of all levels in the file
- Go to the menu Workspace > Function Keys
- Select the desired Key (e.g. F5, F6) and click in the Action field
- Set a command to turn off all levels; enter the following command: set levels off all;selview all
- Choose another Key, click in the Action field once again
- Set a command to turn on all levels; enter the following command: set levels on all;selview all
- Click OK to close the Function Keys dialog
Test the new Function Key commands in a file
Other language sources
| | Original Author: | Conor King | |
