OpenBridge Modeler and OpenRoads Designer Compatibility
OBM and ORD Compatibility Matrix to show the product alignment updated up to the latest release versions:
OpenBridge Modeler Release
Release Date
OBM version #
Compatible with OpenRoads Designer Version
OBM 2025 Update 1
December 2025
25.00.00.362
25.0.0.184
OBM 2024 Update 1
December 2024
24.00.00.263
24.0.0.205
OBM 2023 Update 1
June 2024
10.23.00.01.24
23.00.01.11
OBM 2023 Release
December 2023
10.23.00.0.200
23.00.00.129
OBM CE 2022 Release 2
March 2023
10.12.01.83
2022 Release 2
OBM CE 2022 Release 1
Aug. 2022
10.11.00.310
2022 Release 1
OBM CE 2021 Release 2
March 2022
10.10.20.91
2021 Release 2
OBM CE 2021 Release 1
July 2021
10.10.00.85
2021 Release 1
OBM CE Update 9  (2020 R3)
Nov. 2020
10.09.00.70
2020 Release 3
OBM CE Update 8.2 (2020 R2)
Aug. 2020
10.08.02.45
2020 Release 2
OBM CE Update 8.1 (2020 R1)
May 2020
10.08.01.78
2020 Release 2
We use the same compatible version because users might be using OpenBridge Modeler, and I have compatibility issues with their alignment file from OpenRoads Designer.
Usually, if not doing that, the user will only get an informational dialog that the referenced file has an older schema, but the link from the bridge elements to the alignment could be broken. So, there's a risk, and it's recommended to avoid it.
LARS | LEAP | OpenBridge | OpenTunnel | RM Blog - Now Available - OpenBridge Modeler 2025 (December 2025) v25.0.0.362 - Communities
LARS | LEAP | OpenBridge | OpenTunnel | RM Blog - OpenBridge Modeler 2024 v24.0.0.263 (December 2024) - Communities
