| Version: | pre-X8, V8i and CONNECT Edition | ||
| Area: | DGN | ||
| Subarea: | Save |
How to save a MicroStation V8 file, so it can be opened in versions of Microstation /J and below.
In MicroStation V8 go to File > Save As. In the save as dialog > change the Select Format to "Save as Type" select MicroStation V7 DGN files.
